-   -   Timing of intermediate shaft? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/686695-timing-intermediate-shaft.html)
nimskov 07-02-2012 02:04 AM
I'm rebuilding a 2.7 and just got the case back from the machine shop.
I'll probably have 1000 questions before I'll have it back together... :rolleyes:
First question:
How to time the intermideate shaft?
There is a timing mark on the aluminium sprocket...
I got the Porsche workshop manual (pdf) but it does not say anything bout this subject.
MBruns 07-02-2012 05:54 AM
I/s
There is no timing for that, the cams are timed independently at the sprockets.
Mike Bruns
boyt911sc 07-02-2012 06:57 AM
How lucky we are.........
First question:
nimskov,
We are lucky and fortunate to have guys like Mike B. in this forum. He has saved me many times from disaster in several engine rebuilds that I've done in the past. I've done a few last year and 2 this year, and still asking questions from these guys. It is a never ending cycle and the more you get involve in engine rebuilding the more questions come to mind. Mike B. and Bruce A. both from the south east are my 'help desk' connections and a few others. You are in good company.
Tony
nimskov 07-02-2012 07:33 AM
Allright, so far I've done nothing wrong then :)
Thanks for your help!
HawgRyder 07-02-2012 08:26 AM
BTW...the mark you see on the sprockets (big and small) are the size marks.
There are either 0 or 1 marked on them because Porsche made two sizes (only 2 I think) ... and they should match.
Bob
Eagledriver 07-02-2012 01:16 PM
Bob
Actually there are 4 possible combinations for the 0 and 1 gears and 3 of the 4 are acceptable for each case, depending if it's a 1 or a 0 case.
-Andy
ZOA NOM 07-02-2012 03:50 PM
be sure to check the lash on that aluminum gear
HawgRyder 07-03-2012 09:06 AM
I love this site...as Andy pointed out...the possible combinations of the gears.
If there is any knowledge out there that will solve a problem..it is given freely and quickly in most cases.
How did we ever do it in the old days?....LOL
Bob
j911brick 07-03-2012 10:49 AM
Bob
I just took a motor apart that was rebuilt many years ago, ad I'm sure if you seen it it would answer your question. Allot of motors were assembled incorrectly or poorly.
Speed Buggy 07-04-2012 12:44 PM
Where are the specs for backlash, or what should it be? I have a 3.0L out of an SC. Cheers, Mike.
j911brick 07-05-2012 02:19 PM
I'm not sure how important backlash is on these motors. Its not likely your going to have to little, and if you have to much what are you going to do?
Speed Buggy 07-06-2012 08:17 AM
I guess replace the whole pump. Thanks for the info. I guess I'll just put it in and not look back.
Gunzel 07-16-2012 03:12 PM
Pump
You mentioned pump? What are you talking about.
Mike
j911brick 07-16-2012 05:09 PM
Mike
I'm guessig oil pump. Now that you brought it up he was probably talking about the backlash in the IMS gears. I was thinking crankshaft end play n my last reply. There is a spec for the backlash on IMS gears. I think it involves putting a pin of a specified size between the gears. I think its discussed in the factory manuals, Vol #1.
Gunzel 07-17-2012 04:36 AM
Question
James
Not to be a smart ass, but why not let Buggy answer the question directed to him.
Of course he is talking about the oil pump, the question is why is he doing it. It has nothing to do with the intermediate shaft question.
j911brick 07-17-2012 05:28 AM
Originally Posted by Gunzel (Post 6860659)
James
Really? If you knew what pump he was talking about then why did ask. Get over yourself.
304065 07-18-2012 04:37 AM
Gentlemen. . .
