LinkBack Thread Tools Rating: Thread Rating: 1 votes, 3.00 average.
Timing of intermediate shaft?
I'm rebuilding a 2.7 and just got the case back from the machine shop.
I'll probably have 1000 questions before I'll have it back together...
First question:
How to time the intermideate shaft?
There is a timing mark on the aluminium sprocket...
I got the Porsche workshop manual (pdf) but it does not say anything bout this subject.
/Nimskov
Old 07-02-2012, 01:04 AM
I/s
There is no timing for that, the cams are timed independently at the sprockets.
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 07-02-2012, 04:54 AM
How lucky we are.........
First question:
nimskov,
We are lucky and fortunate to have guys like Mike B. in this forum. He has saved me many times from disaster in several engine rebuilds that I've done in the past. I've done a few last year and 2 this year, and still asking questions from these guys. It is a never ending cycle and the more you get involve in engine rebuilding the more questions come to mind. Mike B. and Bruce A. both from the south east are my 'help desk' connections and a few others. You are in good company.
Tony
Old 07-02-2012, 05:57 AM
Allright, so far I've done nothing wrong then
Thanks for your help!
/Nimskov
Old 07-02-2012, 06:33 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
BTW...the mark you see on the sprockets (big and small) are the size marks.
There are either 0 or 1 marked on them because Porsche made two sizes (only 2 I think) ... and they should match.
Bob
Bob Hutson
Old 07-02-2012, 07:26 AM
Bob
Actually there are 4 possible combinations for the 0 and 1 gears and 3 of the 4 are acceptable for each case, depending if it's a 1 or a 0 case.
-Andy
Old 07-02-2012, 12:16 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
be sure to check the lash on that aluminum gear
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 07-02-2012, 02:50 PM
HawgRyder's Avatar
I love this site...as Andy pointed out...the possible combinations of the gears.
If there is any knowledge out there that will solve a problem..it is given freely and quickly in most cases.
How did we ever do it in the old days?....LOL
Bob
Bob Hutson
Old 07-03-2012, 08:06 AM
j911brick's Avatar
Bob
I just took a motor apart that was rebuilt many years ago, ad I'm sure if you seen it it would answer your question. Allot of motors were assembled incorrectly or poorly.
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 07-03-2012, 09:49 AM
It's a trap...
Speed Buggy's Avatar
Location: 1/2 way between the Motor City and the Glass City.
Where are the specs for backlash, or what should it be? I have a 3.0L out of an SC. Cheers, Mike.
Run like the wind, straining the limits of machine and man....
2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys).
Old 07-04-2012, 11:44 AM
j911brick's Avatar
I'm not sure how important backlash is on these motors. Its not likely your going to have to little, and if you have to much what are you going to do?
james
Old 07-05-2012, 01:19 PM
It's a trap...
I guess replace the whole pump. Thanks for the info. I guess I'll just put it in and not look back.
Old 07-06-2012, 07:17 AM
Pump
You mentioned pump? What are you talking about.
Mike
Old 07-16-2012, 02:12 PM
j911brick's Avatar
Mike
I'm guessig oil pump. Now that you brought it up he was probably talking about the backlash in the IMS gears. I was thinking crankshaft end play n my last reply. There is a spec for the backlash on IMS gears. I think it involves putting a pin of a specified size between the gears. I think its discussed in the factory manuals, Vol #1.
james
Old 07-16-2012, 04:09 PM
Question
James
Not to be a smart ass, but why not let Buggy answer the question directed to him.
Of course he is talking about the oil pump, the question is why is he doing it. It has nothing to do with the intermediate shaft question.
Old 07-17-2012, 03:36 AM
j911brick's Avatar
James
Really? If you knew what pump he was talking about then why did ask. Get over yourself.
james
Old 07-17-2012, 04:28 AM
304065's Avatar
Gentlemen. . .
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 07-18-2012, 03:37 AM
