2.0 engine cylinder boring
Can you bore the cylinders on a 2.0 and if so and how much? Looking to clean up the cylinders for a rebuild.
You can bore them up to .020" oversize.
And if you were not going to already, you might want to consider torque plates. They definately make a difference, even on cast iron cylinders.
81
| All times are GMT -8. The time now is 06:51 AM. |
