3.4L Ignition timing help
Looking to see if you guys have any thoughts on baseline timing:
3.4L (3.2L with 98mm cylinders); 9.5:1; 46mm PMO carbs; stock 3.2 cam; electromotive crankfire; single plug |
I would think that you can use stock ignition timing for the 3.2. But Not sure how much advance you can add to it on higher revs.
| All times are GMT -8. The time now is 05:56 PM. |
