1978 911SC , 1974 914 1.8
prepping parts for rebuild-OK to paint or powdercoat oil return tubes?
I'm still preparing a few parts for assembly on a 1978 3.0 litre motor. I bought new oil return tubes (solid) which look nice now, but I assume will discolor and rust in no time. Is it safe (as in no oil temperature rise) to spray paint or powder coat these four oil return tubes , or should I just leave them alone? Thanks for your help, regards, Paul
Old 08-13-2012, 12:10 PM
Champagne on Beer Budget
HelmetHead's Avatar
I would use at minimum a Radiator paint >1000F as those tubes run right above the exhaust and also high head temperatures will cook them. We use the same 1000F paint on the engine tins between the cylinders..
Einar
www.einarsgarage.com
Instagram @einars_garage
https://www.facebook.com/pages/Einars-Garage/375533809160797
Old 08-13-2012, 01:15 PM
Powdercoat would be good in that application.
'90C4
Old 08-13-2012, 04:41 PM
Thanks for the information as.....
I remember reading here NOT to paint or powdercoat a particular part (can't remember) due to it somehow causing the oil to rise in temperature. Given these oil return tubes location, figured it was worth asking. Thanks again, Paul
Old 08-14-2012, 05:24 AM
