-   -   993 turbo help (http://forums.pelicanparts.com/911-engine-rebuilding-forum/698581-993-turbo-help.html)
Burkey 08-25-2012 06:43 AM
993 turbo help
Looking for some help, I am in the middle of a re-build without a turbo manual :eek: looking for the piston to cylinder wall clearance spec as well as the Ring end gap specification for ring 1 and 2. Would really appreciate it if someone could send me the pages on the heads as well, that is where the problem is dropped 2 valve guide's. Just trying to check everything while I am in there.
Thank-you
Burkey
mamut 09-12-2012 05:22 PM
Try Rennlist.comSmileWavy
Thank-you
Burkey
