Advice sought....2.2E or 2.4S pistons with E cams
I am looking for the advice of the experts, please. I am having a stock 1972 911T 2.4 MFI engine professionally rebuilt. The MFI I'll be using is straight off of a perfectly running 2.2 E engine. The cams are new E cams. The quandry is, which pistons and cylinders should I use? I want the engine to be the strongest and fun, but street-usable as possible. I have two good sets. One set is 2.4 S pistons and cylinders, and the others are 2.2 E pistons and cylinders. I know the E pistons will offer higher compression, but I think the 2.4 pistons were also really good, right? I just don't know which to choose! The heads are the standard small valve 2.2/2.4 MFI heads with stock ports. I would so much appreciate your kind advice on this topic! Thanks in advance!
Home of the Whopper
I had a 2.4E with 2.4S pistons in several of my cars. IMO the best engine I ever had. Now I am building up a 2.4E with 2.2E pistons for that extra compression bump. Should be even better! I don't think you can go wrong either way.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
up-fixing der car(ma)
2.2 E, more compression, and keep the revs under 7k, because they are cast pistons
Scott Kinder kindersport @ gmail.com |
I believe the OEM spec (Mahle) for the 2.2E is all cast.
ASE Master Tech - 35 yrs
search this & 911 forum for "cams" & "DRC"
- you are doing a mix-n-match that is fraught with conundrums - visit DRC site at the very least .
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
