Noisy Generator Bearings?
Aloha from Maui,
My 1974 Carrera has a clunky sound coming from the fan housing that sounds like some bearings going out. What parts do I need to order to fix it? The generator is charging fine, and the car is completely bone stock and 100% original. Mahalo Gregg Bluehttp://forums.pelicanparts.com/uploa...1346294999.jpg http://forums.pelicanparts.com/uploa...1346295023.jpg |
alternator
This forum thread on Rennlist may be helpful to you.
http://forums.pelicanparts.com/porsche-964-993-technical-forum/686617-964-alternator-rebuild.html Also, did you take off the belt to make sure the noise is from the alternator? And, you can order a rebuilt from Pelican... Regards, |
just pull it out & take to your local rebuilder - will cost about $125 and will be perfect
i have '2' 3.2 units done recently at that price -california prices, no less . |
Thought mine was alternator bearings only to soon discover cam lobes for cylinders 4 & 5 were running dry. :rolleyes: |
| All times are GMT -8. The time now is 10:01 AM. |
