-   -   993 head studs loose after rebuild? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/705294-993-head-studs-loose-after-rebuild.html)
berni29 09-14-2012 06:14 AM
Hi There
I did a top end rebuild on my 993. The engine was oil tight at first, but after a very few miles is now weeping oil heavily from the cylinder bases. I was very careful torquing the heads, but is it likely/possible that they need torquing again? I did not replace the studs. Also can the heads be re-torqued with the engine in the car?
I used a Wrightwood racing gasket set and a smear of hylomar blue.
Thanks in advance for any opinions.
Berni
earossi 09-14-2012 06:24 AM
If you are leaking at the base I doubt that loose studs are the issue since there was crush on the base O-ring and low pressure drop across that gasket. Sounds like the gaskets have been compromised. I am not familiar with the paste you applied to the O-rings but suspect that to be suspect since it sounds as though you have had multiple seal failures. Most literature I have seen suggests installing those O-rings dry or with Curill.
E Sully 09-14-2012 12:55 PM
What torque did you use originaly on the head studs?
Lapkritis 09-14-2012 03:16 PM
The head studs on these aren't torque to yield/stretch?
