-   -   do these numbers ring true?? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/707830-do-these-numbers-ring-true.html)
duke of boots 09-23-2012 03:07 PM
I purchased a rebuilt 1966 911 2.0L engine and would like to know if these numbers ring true for the year?
Cylinder - 80ZD3
Heads - K1819B, R90110430304
Piston - 1030784
Distributor - Bosch 0231 159001
Alternator - D120 400 522
Engine No 900943
Does this all appear to be right for year?
Many thanks
Flat6pac 09-23-2012 05:12 PM
The head numbers work.
Piston should be Mahle 80V37 on the inside casting
Bruce
duke of boots 09-24-2012 04:23 AM
Thanks Bruce, the piston number I had to get from the top of the piston using an endoscope as engine is complete. The 103 sits above an m and the 0784 is directly below the 'm' marking. The other marking is on the cylinder which is an 'm' above what looks like a three pronged crown???
Flat6pac 09-24-2012 05:18 AM
You ll probably find the correct number inside the piston then.
Bruce
tom1394racing 09-24-2012 05:54 AM
Cylinder - 80ZD3 - correct
Heads - K1819B, R90110430304 - Correct
Piston - 1030784 - should look like attached pic
Distributor - Bosch 0231 159001 - Correct
Engine No 900943 - A '66 engine should have a S/N starting with 903. S/N 900943 would indicate a 1965 engine
http://forums.pelicanparts.com/uploa...1348490900.jpg
http://forums.pelicanparts.com/uploa...1348490937.jpg
duke of boots 09-24-2012 07:17 AM
Thanks guys, as engine is still together will have to try and view pistons from below with optics. Tom, thanks for date correction.
duke of boots 09-25-2012 01:52 PM
pistons confirmed
Thanks Bill, confirmed tonight with endoscope that i have the piston pictured above. Found the casing numbers which are 133/133. So it looks like a have a pretty original rebuilt motor.
47silver 09-25-2012 02:10 PM
endoscope
what brand of endoscope did you use?
duke of boots 09-25-2012 02:23 PM
litetec
