-   -   '83 Euro Intake Port Size (http://forums.pelicanparts.com/911-engine-rebuilding-forum/709251-83-euro-intake-port-size.html)
FrankyV 10-01-2012 09:13 AM
There is some conflicting information out there, can anyone point me to a definitive source regarding the intake port size (large or small) for an '83 Euro motor ?
Flat6pac 10-01-2012 03:50 PM
All the euro or ROW are large port. Small port was for the US Lambda system cars.
Bruce
tom1394racing 10-02-2012 04:42 AM
Intake ports are 39 mm for a large port SC
Mark Henry 10-07-2012 07:19 AM
So if you have one damaged '79 head any ROW SC head would do as a replacement?
tom1394racing 10-07-2012 07:27 AM
Yes that is correct. The early big port SC heads will have the air injector hole in the exhaust port that will need to be plugged. If you are using the air injection on an early SC, the late ROW big port heads would need to be drilled and tapped for the air injector.
Flat6Heaven 10-27-2012 07:43 AM
Hmm, my '82 SC 930/16 has air injection heads.
