ASE Master Tech - 35 yrs
Did those older 911's have higher normal oil pressures than the 3.2?
The oem guage and sender are 10 bar (with no oil warn lite) The 3.2 sender is 5 bar, and the Bentley book says it is regulated at 4.5 (59 psi) - - - what were regulated psi on the earlier engines? there must have been a reason the factory installed 10-bar 'way back in the stone age ??? - various authors including Wayne & Bruce say 10psi/1000 minimum; Anderson (2nd ed) further suggests "anywhere from 4-bar-to-9-bar (130 psi) can be "normal", not to exceed 9 bar (10-bar seems worthless if the 3.2 is truly regulated at 4.5 bar at 6500) how much psi is "enuf' - at what rpm ????????? RESOLVED - I used the 3.2 with oem senders and put in an '80 SC gauge to match TIA
"... I am German, and if it has no logic it's meaningless." 911 parts FS https://tinyurl.com/911-parts-FS-12-2020 ![]() 914 & 914-6 parts FS 03-2021 ![]() Last edited by larrym; 03-13-2013 at 06:31 PM.. Reason: clarification |
Either way will work as long as the dash matches the sender on the engine.
Bruce |
Thread Tools | |
Rate This Thread | |
