Engine #6135776 lookup please
I have this engine on a stand and interested in its original donor. Could someone provide a lookup please?
It looks to be a 2.7 case with big bore intake heads, carrera tensioners and webers but there are lots of mixed bits on the car it came from. Thanks! |
Heads are 38mm intakes, listed in Bruce's book for 906 and 911R racing engines, 911/20, 911/21, 911/22 for "racing engines fuel injected" and "racing engines Weber 46IDA carbs".
My 1973 2.4 cis engine number is 6135865. Yours seems to be a little earlier. What is the other number stamped by the cylinder, mine is 911/91.
John
That S/N corresponds to a 1973.5 911T. This would have a 7R case like the 2.7 but with smaller spigots for the 84 mm cylinders. The stock configuration would have the unique 2.4 CIS heads with an injector hole and the 30/33 mm ports |
Thanks Ed and Tom. The PO represented the motor as a "2.7 built to RS specs." Its another Pelican, but the statute of limitations is up so I wont name names unless he wants to pipe up.
I need to finish stripping the rest of the car now and get a big order into Pelican ASAP so just trying to guess what motor bits I'll need before actually tearing it down. It ran fine before but I still plan on rebuilding it over the winter. So, a 2.4 case with what is reported to be 2.7 jugs and mahle pistons and S cams....it was fun when it ran, lets see whats going on inside... |
John
The 2.4 case can be opened up at the spigot bores to accept the 2.7 cylinders. With those big ports, the engine is obviously not stock. |
| All times are GMT -8. The time now is 01:33 PM. |
