-   -   Advance Curves (http://forums.pelicanparts.com/911-engine-rebuilding-forum/710818-advance-curves.html)
Weissach911 10-11-2012 05:16 AM
Advance Curves
The subject of re-curving SC distributors keeps cropping up and I have found it impossible to buy springs specifically for the Bosch dizzy.
I have found plenty of Lucas springs but they don't fit.
Does any one know if the Mallory Springs work?
Mallory Ignition 29015 - Mallory YL Distributor Advance Curve Change Kits - Overview - SummitRacing.com
JFairman 10-11-2012 09:00 AM
If you're looking for stiffer springs to delay the centrifical advance and can't find any you can try lightening the steel advance weights by removing them and drilling a hole(s) in them.
Drilling holes in the advance weights would be better than grinding metal off the ends because if you lighten them too far you can always braze the holes back up with brass rod.
chris_seven 10-11-2012 09:55 AM
Good idea - Thanks.
jason2guy 10-20-2012 04:23 PM
check this site out
Porschetechnik Vintage Porsche Parts Store & Restorations
my advance comes in too quick, old springs.
this guy apparently has some. its worth a try to put them in
and check out the results w/a timing light before going the
rebuild/recurve route
chris_seven 10-22-2012 09:25 AM
http://i197.photobucket.com/albums/a...Lane/Dizzy.jpg
I bought one of these to try to really get to grips with dizzy rebuilds, I would have preferred a moder King machine but at around $7000 it was out of my budget. :)
