peppy's Avatar
how long can a fresh rebuild sit?
How long can I wait to start my fresh rebuild? What do I need to do?
I'm waiting on the DME Computer to be fixed (I screwed it up).
Thanks,
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 11-10-2012, 09:51 AM
You have the engine in the car, just add oil and bring pressure up on the guage, you dont need the brain to turn the engine over.
Bruce
Old 11-10-2012, 12:30 PM
I would most definitely bow to Bruce's greater knowledge....however as a data point, when I had my Kremer done in Germany, they finished the engine in 1989 and I did not get it into the car and running until 1995. Since then it has ran like a train, I have about 40,000km on it, never had a problem or issue with it.
Only negative so far is that there is a small amount of oil weeping at one of the cylinder/head joints. Seems very minor...
Dennis
Old 11-10-2012, 12:54 PM
304065's Avatar
Mine sat for a couple years while I finished the car. I put preservative oil in it and dessicant plugs in the spark plug holes.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 11-10-2012, 01:26 PM
peppy's Avatar
Will the engine turn over with the key or do I have to rig something? I already put the oil in.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 11-10-2012, 01:34 PM
304065's Avatar
Did you turn the engine over on the stand before you installed it in the car? Does it turn over with absolutely no issues whatsoever when you do it by hand? You should be absolutely certain it turns over with no abnormal resistance before you hit the starter. Anyway, when you turn it over with the starter, this will pressurize the oil system and distribute oil where it needs to go. As Bruce said, you don't need the DME to crank the engine with the starter.
'81 R65
Old 11-10-2012, 02:43 PM
peppy's Avatar
Yes, the engine turned over by hand.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 11-10-2012, 03:31 PM
With the plugs out, go for it...
Bruce
Old 11-10-2012, 03:48 PM
