-   -   930 Oil pump in early case, what did you do for a sump plate? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/712866-930-oil-pump-early-case-what-did-you-do-sump-plate.html)
fastfredracing 10-23-2012 07:07 AM
I grabbed an early sump plate that is concave, with no drain plug, but I am still getting slight contact with the Turbo Oil pump screen.
Anyone used one of the Mainley sump plates that our host sells? Looks like they have a slightly deeper recess. I like the factory style plate better for asthetics though.
I was also thinking of just shimming my factory style plate down with an old sump screen with the screen removed, and two gaskets .
Would like to hear some of your solutions .
sjf911 10-23-2012 08:43 AM
I have one and it also contacts the pump screen.
KTL 10-23-2012 12:41 PM
I have a Mainely and it's a very nice pice. Also comes with a magnetic drain plug which is nice. It clears my 964 pump (similar screen dimensions as 930 pump) installed in a SC case no problem.
Supertec & Rennworks also make a nice vintage looking aluminum sump plate.
Both of the plates are in Pelican's catalog Porsche 911 Oil Circulation - Page 7
Not a bad idea to shim it down if you want to. Also not a bad idea to remove the screen. As they get older, the screen can sometimes break free of the flange.
http://forums.pelicanparts.com/porsche-911-technical-forum/508697-how-often-do-you-open-up-your-sump-plate.html
