-   -   Best way to square piston rings in bore for measuring? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/714289-best-way-square-piston-rings-bore-measuring.html)
SergiuM 10-31-2012 05:56 PM
I'm trying to measure my ring end gaps on my 930, and i can't use the pistons to square the rings in the bore due to the shape of the piston head. What should i use? I don't know what the tool for it is called..
mreid 10-31-2012 06:20 PM
Use a ring compressor. You do have one, right?
Flat6pac 10-31-2012 06:25 PM
Use the bottom of the piston. Top of the turbo piston is flat. I dont see why you couldnt use it.
Bruce
SergiuM 10-31-2012 06:28 PM
How would you do it with a band-type compressor?
SergiuM 10-31-2012 06:30 PM
Bruce
Stupid me. I meant just the regular SC engine.. Not a 930. :(
KTL 11-01-2012 07:38 AM
Use a pair of calipers with a depth gauge on them. Put the ring in the cylinder and then check the depth of the ring from the top edge of the cylinder spigot down to the ring surface. Check around the perimeter of the cyl in several places and get your depths all the same. Then you're square.
AlfonsoR 11-01-2012 09:01 PM
You can google "ring squaring tool". You might find something cheaper than these... JEGS Piston Ring Squaring Tools - JEGS
You may also want to check the Stomski web site. They sell several Porsche specific tools.
88911coupe 11-02-2012 12:24 PM
What KTL said...
