-   -   Any downside to using new studs on case perimeter? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/720309-any-downside-using-new-studs-case-perimeter.html)
Baby 11-29-2012 10:10 AM
Another studs question since the case is apart again: any potential downside to installing new perimeter studs instead of re-installing the studs that were removed when the case was cleaned? Do they just get threaded in with loctite and set to the correct height? Is the case or case threads compromised in any way?
Dick Shift 11-29-2012 10:18 AM
any potential downside to installing new perimeter studs? just unnecessary
re-install the studs that were removed when the case was cleaned.
Do they just get threaded in with loctite and set to the correct height? Yes
Is the case or case threads compromised in any way?No, as long as you torque no more than 18ft #
Just Get U done!
Baby 11-29-2012 11:38 AM
Thanks, Dick. I ask because a few backed out with the locknuts on them. The locknuts don't want to come off with the double nut method. I cut one off with a dremel and cutting wheel and left the slightest groove perpendicular across the threads. Probably no big deal, but I may get new ones (if I can find them) for peace of mind.
