Question on rear axle / hub assembly sequence
I'm going to have my p-car mechanic press in my new trailing arm bushings and wheel bearings on my driver's side trailing arm. I figured, might as well have him press hub into the bearing as well.
Question: what gets bolted to the TA prior to the hub getting pressed in? Is it the entire e-brake assembly and the retaining plate? I want to make sure I show up with all the parts needed. thx Rich |
The PET shows only item 13, the retaining plate, behind the hub, but I'm not sure if the ebrake assembly also needs to go on. I would think it does but PET doesn't have an exploded diagram showing it all together.
http://forums.pelicanparts.com/uploa...1354290567.jpg |
You will get more answers in the 911 forum, this is the engine rebuild Forum
Whoops!
Figured it out anyway. Thx |
| All times are GMT -8. The time now is 08:15 AM. |
