-   -   Where can I get case perimeter studs? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/723341-where-can-i-get-case-perimeter-studs.html)
Baby 12-11-2012 04:08 PM
PP is fresh out of 32-mm (exposed) studs. Anyone know where I might find them? I need 6... For a 83.
KTL 12-12-2012 10:26 AM
If you've got an old cam housing lying around, the exhaust/lower valve cover uses 35mm studs. I have a bunch of them if you'd like some.
Baby 12-13-2012 03:38 PM
Thanks kindly for the offer, KTL. I was able to locate some at the local air cooled VW race shop. 45mm total length, which is just one or two mm shorter than what I had.
