-   -   How do I remove this (http://forums.pelicanparts.com/911-engine-rebuilding-forum/723928-how-do-i-remove.html)
irl 12-15-2012 11:47 AM
What tool do you use to loosen/tighten this linkage connection bolt on a weber? Its smooth and I can figure out how to grab it to loosen it. I had it posted in the tech forum but i should have tried here i guess.
thks
http://forums.pelicanparts.com/uploa...1355600852.jpg
irl 12-15-2012 02:35 PM
Anyone??
HawgRyder 12-15-2012 03:45 PM
Is it screwed in or pressed in?
If screwed...possibly a strap wrench might work.
For a press in pin...a shaft gripper (like a socket with inward moving grips) and a slide hammer would work.
Bob
irl 12-15-2012 03:48 PM
Thanks, this is a pretty common part, anybody know this answer.
Eagledriver 12-16-2012 11:35 AM
My first instict would be to not remove it. Do what ever work you are doing with it installed. If I had to remove it I'd grab it with a pair of vise grips, use some scrap aluminum to cushin the jaws so they don't scratch and dent the shaft. To break it loose I'd heat the base with a propane torch. This will expand the magnesium and loosen any locktite.
-Andy
MBruns 12-16-2012 04:05 PM
Shaft
Warm up the manifold and it will slide right out, to reinstall heat and a drop of green loctite
Mike Bruns
irl 12-16-2012 09:43 PM
Thanks everyone, where could I buy one if I broke it :)
KTL 12-17-2012 08:58 AM
Is that a theoretical question or an admission of guilt? :D
Give PMO a call, as I think this rod is included in their MFI linkage kit? See picture at bottom of page- looks like the shaft is next to the manifold spacers
PMO High Performance Porsche 911 Carburetion
I suspect Richard would have no problem getting you just the shaft alone.
