-   -   help identifying o-ring from re-build kit (http://forums.pelicanparts.com/911-engine-rebuilding-forum/725660-help-identifying-o-ring-re-build-kit.html)
jomalkay 12-27-2012 08:28 AM
Need some help in identifying this o-ring, is approx 31mm OD, 27mm ID and 5mm wide, not a round type more of oblong. Kit is westwood and there is only one of these included so i am thinking must be for the crankshaft? Did not see any call-out in any of the reference books i have. thanks.http://forums.pelicanparts.com/uploa...1356625614.jpg
mreid 12-27-2012 08:42 AM
What year? Looks like a thermostat o-ring or distributor seal, but the year would help.
john walker's workshop 12-27-2012 08:42 AM
power steering pump bracket into cam tower. 964/993. you should post the year of the car with your question.
jomalkay 12-27-2012 08:48 AM
Sorry about the year, is from a 3.2L lower Westwood rebuild kit, motor year is a 1986. I have identified all other seals in the kit (not the thermostat). I am waiting on a new dizzy, so I do not have this part to compare.
356RS 12-27-2012 09:18 AM
Could be for the distributor shaft maybe?
jomalkay 12-27-2012 10:13 AM
Must be the distributor, not having the old dizzy on hand was difficult figure out, but I am sure this I the correct seal. Moral of the story may be do not sell off parts you do not need until after the rebuild is finished! Feeling kind of stupid as this is common seal that needs replaced. Live and learn. Thanks to all.
