nreed's Avatar
Loctite 510
Please forgive me but I have done some research on the Loctite products.
1. 574 is special order locally. People look at you strange!
2. 510 cures much slower, 22 deg C 50% in 3 hrs (574 50% in 45min). Much more forgiving of DIY types IMHO.
3. Up to 200C temperature, degrades to 50% at 200 deg C (574 hot strength degrades to 25% at 150C)
4. $20CA for 50ml size.
5. Loctite recommends a primer for aluminum, p/n 19269
6. 574 remover (in case you tried and did not like 574 )- p/n 79040
7. 518 is also a good alternative to 574 but cures up faster. Cure time is very similar to 574. In my opinion a little too fast for a DIY guy!
FWIW, Hope this helps someone.
Norm '86 930
AEM Infinity 6 - Twin Plug 3.6L - DBW - JE Pistons/LN Eng. Cylinders - Pauter rods - GT3 Crank - GTX3584RS - ID1050x Injectors - Ported Intakes - Custom Intake Manifold, exhaust and intercooler - 993SS cams - ECUMASTER PMU-16DL
HRE Wheels 560R 8.5x18 ET25 (Front) 11x18 ET0 (Rear)
Old 05-11-2004, 10:22 AM
nreed's Avatar
P.S.
Loctite has good data sheets
Norm '86 930
Old 05-12-2004, 04:57 AM
Banned
How about 573? I only can find 573 and 510 in my country. Have any one use 510 for a high power 930 3.3 engine?
Old 01-12-2013, 07:32 AM
nreed's Avatar
I had excellent results with 510. My engine has been running strong with no leaks since rebuild in 2004.
Norm '86 930
Old 01-12-2013, 01:39 PM
Thanks Norm, this is actually quite timely. I'm looking for engine sealants at the moment.
Old 01-16-2013, 09:18 AM
nreed's Avatar
Places like Benson's and Ottawa fasteners carry 510.
Norm '86 930
Old 01-19-2013, 04:20 PM
Yes, 510 was my choice too.
P 964 C2 1992 with some minor changes
Old 01-28-2013, 12:23 PM
