Ring ID
I've worked my way up to the P & Cs. Planning to re-use the rings, assuming the end gaps measure up. I notice there aren't any markings on the first compression ring and the oil ring. The second compression ring has "TOP" stamped into the top. I'm curious about what I have here.
Here are a couple pics of the first compression ring. Is it stock or maybe some other ring? TOP http://forums.pelicanparts.com/uploa...1359057366.jpg BOTTOM http://forums.pelicanparts.com/uploa...1359057477.jpg |
| All times are GMT -8. The time now is 08:39 AM. |
