-   -   WTB: piston Cylinder..adj pict.. (http://forums.pelicanparts.com/911-engine-rebuilding-forum/730901-wtb-piston-cylinder-adj-pict.html)
nardiporsche 01-26-2013 11:29 PM
http://forums.pelicanparts.com/uploa...1359271770.jpg
thanks
JP
Flat6pac 01-27-2013 10:22 AM
What you need to complete the request is bore size, stamped on the outside of the cylinder on the top. 0, 1, or 2 next to the deck height which is a triangle with a 5 or 6 inside it.
If you want the piston to match yours you need to post the 95xxx number cast inside the piston.
Youre looking a KS alucil so you should look a piston and cylinder unit that has already run together.
Bruce
tom1394racing 01-27-2013 10:51 AM
I can provide a P&C pair
Walt Fricke 03-16-2013 06:49 PM
Tom is a good guy.
304065 03-16-2013 06:56 PM
Originally Posted by Walt Fricke (Post 7333275)
Tom is a good guy.
well said!
