-   -   WTB 1 cylinder and piston set (http://forums.pelicanparts.com/911-engine-rebuilding-forum/731092-wtb-1-cylinder-piston-set.html)
yelcab1 01-28-2013 01:55 AM
I need to replace one cracked piston/cylinder from a 3,2L Carrera 1987.
KS, Alusil, group height 6, is preferred.
If I can't find KS, is it possible to replace with a Mahle Nikasil cylinder and piston set? Is there a problem when the other five cylinders find out that the sixth brother is not from the same mother? Will they play nice?
Any lead on the KS unit is appreciated. Somebody here must have a set lying around.
tom1394racing 01-28-2013 10:30 AM
I have a KS P&C pair for you. See your PM
