-   -   Cams (http://forums.pelicanparts.com/911-engine-rebuilding-forum/732020-cams.html)
mr Piebenga 02-01-2013 08:42 PM
Cams
I have at 3 litre injected sc I am in the process of doing a weber conversion and was hoping someone could help me with cam advice
Thanks Derek
Steve@Rennsport 02-01-2013 10:01 PM
Derek,
Are you keeping the stock pistons?
If so, the biggest cams you can use in there is the 964 grind, and with a good exhaust system, gives very nice performance.
KTL 02-03-2013 07:58 AM
Lots of other variables come into play when selecting the cam. But Steve makes the best point to start- what pistons are you using.
If you get some pistons that are more carb-likeable, S cams are a nice tried and true choice. They are peaky on the smaller 2.0, 2.2L engines. But in the larger displacement engines the peakiness is much less prominent.
I had S cams (actually WebCam's 149S grind) in my 3.2SS for a number of years. It made nice power and could hold its own against larger torquier engines like 3.6 993s and BMW M3s. Mostly because we are regulated by weight/power ratio.
I swapped to WebCam 120/104 last season, which is said to be a hot street/club race cam, and it seemed to have a broader power band. Can't provide much else feedback on that cam because I blowed up the engine after one race weekend..... But I won so it had to be not too bad?
Lapkritis 02-03-2013 09:49 AM
I'm sending out to Web shortly, guess I'll need to find out what piston spec I have on my 2.7.
