Rennline block of plates and blower motor cover installed!
https://lh6.googleusercontent.com/-j...120_145534.jpg |
subscribed!
very nice documentation of your progress, please keep us updated. i like the two tone (tan/black) of your interior & the exterior color as well! |
Hello,
Cool picture in the site,otherwise every information are good.I will agree to other member,i personally talk about the site with my friend.thanks Sacramento Airport Shuttle |
Replaced the Clutch cable. Removed it from where it connects to the front of the tunnel, then pulled it out through the rear. Fed the new one in and reconnected it at the front.
https://lh4.googleusercontent.com/-D...203_145540.jpg Cleaned out the fuel filler and replaced the fuel filler flap https://lh6.googleusercontent.com/-u...205_144231.jpg Replaced the rear deck lid strut with pelicans dual heavy duty strut! These two shocks are easy to install and hold the lid up with no struggle https://lh6.googleusercontent.com/-k...205_143942.jpg New fuel pump and fuel lines with correct banjo fitting https://lh6.googleusercontent.com/-2...205_172046.jpg New fuel pump and fuel lines installed https://lh4.googleusercontent.com/-s...215_152458.jpg New fuel tank Installed from Porsche, reused the Vdo fuel level sending unit, Rust clean up will follow on front battery tray https://lh4.googleusercontent.com/-w...215_152533.jpg Painted the rear engine compartment https://lh4.googleusercontent.com/-f...219_165617.jpg |
You need 17 to 20 turns on the clutch cable into the clevix in order to be able to adjust the clutch without running out of threads in the rear.
Bruce |
2.7 rebuild specifics
Nice thread. Thanks for posting. curious about the 2.7 rebuild you are going to do. You could add 9.5 JEs,40 mm carbs, E cams, SSI 2 in I out muff. but would that give you the 230 hp you requested? Wouldn't that be 200 to 210? best
Awesome thread. I just started the rebuild of my 77. Going to go with a 3L engine. Fuel tank is out getting cleaned, that was the first step after collecting the pieces and parts from the seller. Was debating about whether or not to go with the wide body look. Afte seeing yours... Done! It's going to happen!
More updates Rennline Pedals installed https://lh4.googleusercontent.com/-9...222_154054.jpg Oil tank going back in after being cleaned up and repainted from paciffic oil coolers new gasket on the oil level sending unit and new boot for the wire! Ground wire added https://lh6.googleusercontent.com/-1...222_153706.jpg New tail lenses installed https://lh6.googleusercontent.com/-8...222_153608.jpg New engine+transmission mounts in Oil filter ready to go! https://lh6.googleusercontent.com/-k...231_141449.jpg |
Love the progress! Curious - where did you get the rockers from?
They were installed by one of the previous owners! They look like they have been on the car for a long time and it looks like they were installed with coopper:confused: New sunvisors installed from Porsche! https://lh3.googleusercontent.com/-c...109_172153.jpg Still waiting on the engine!!!! |
Fuel lines are going in with the fuel filter and the crank case breather.
Big thanks to Len Cummings at Auto Sport Engineering for making some lines for me from the tunnel lines up! These were direct fit! https://lh4.googleusercontent.com/9q...KzeQaw=s615-no Modified oil catch can will be going in next! https://lh6.googleusercontent.com/-H...204_122050.jpg |
Installed the Crank case breather after shortening it 2 inches and putting a new hose fitting on it from 1.5 inch to 1 inch to accommodate a 1 inch hose from the oil tank to the breather, Then changing out the drain fitting from a straight to a 90 degree brass fitting for easier routing.
https://lh4.googleusercontent.com/-a...220_201151.jpg Glued in the door seal and screwed in the felt seal that runs on the top of the door jam https://lh5.googleusercontent.com/-L...220_193844.jpg https://lh4.googleusercontent.com/-s...220_194218.jpg Doors seals nice and snug now:D |
Installed some Recaro sportster seats!
http://forums.pelicanparts.com/uploa...1400220100.jpg http://forums.pelicanparts.com/uploa...1400220224.jpg Have the Msd in place! http://forums.pelicanparts.com/uploa...1400220326.jpg Battery in the smugglers box! http://forums.pelicanparts.com/uploa...1400220366.jpg New key and key head! http://forums.pelicanparts.com/uploa...1400220408.jpg Cleaned up the transmission! http://forums.pelicanparts.com/uploa...1400220463.jpg Pictures of the engine! http://forums.pelicanparts.com/uploa...1400220627.jpg http://forums.pelicanparts.com/uploa...1400220676.jpg Dyno numbers! http://forums.pelicanparts.com/uploa...1400220746.jpg |
Wow, great numbers. That thing will haul butt...too bad it wasn't a local that did the build, I'd have to talk with them about mine, haha.
Got the car running on 6/16/14 I've included a link of the car running and some pictures of it out of the storage unit SmileWavy
Link to car running and walk around video! 77 porsche 911 2.7 walk around - YouTube Engine about to go in https://scontent-a-iad.xx.fbcdn.net/...86518566_n.jpg Engine in! https://scontent-a-iad.xx.fbcdn.net/...ab&oe=546960F3 Gas station https://fbcdn-sphotos-d-a.akamaihd.n...616e0e24e6163f Top of Skyline Drive in Virginia https://fbcdn-sphotos-f-a.akamaihd.n...10880416_n.jpg Thank you for all the help and support! Couldn't have done it without the help of so many great people on this website. |
Walk-around video looks like a for-sale video...but I don't think that's the case, right>?
It's on eBay
Very nice car! If I was in the market I'd be all over it. Good luck with sale!
| All times are GMT -8. The time now is 07:30 AM. |
