EFI Fuel Injectors
Question regarding fuel injectors and technology.
Is there a compelling reason to choose high impedance injectors over low impedance?
Has there been real improvement in Fuel Injectors over the OEM injectors in my 1987 911 Carrera?
Considering update to EFI for improved ability to properly tune the Air Fuel ratio and gain a little more efficiency.
Thanks,
John
JT
Old 02-10-2013, 10:07 PM
Turbonut
Raceboy's Avatar
Fuel injectors have been through big improvements over old EV1 style design.
Newer, "pencil" style injectors have better atomization, better response (less dead-time) and can cope with wider range of pressures and different fuels.
Some Bosch EV12 or Siemens Deka injectors would be my choice anytime over old style ones.
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 02-10-2013, 10:48 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
The difference in impedence may have to do with the response time (reluctance of the coil).
The high impedence one may limit the RPM factor of the engine?
Bob
Bob Hutson
Old 02-11-2013, 12:37 PM
Turbonut
Raceboy's Avatar
Bob
There is no practical difference other than control method.
Old 02-11-2013, 09:08 PM
Straight shooter
Lapkritis's Avatar
You can always add a resistor on low impedance if your ecu only drives high impedance injectors. I run the Siemens deka on my non-Porsche turbo application and studied up quite a bit before purchase. Given the single valve/narrow port on the Porsche, the deka may not be the absolute ideal spray pattern but considering some of the tech the fuel traveled through from the factory it is likely to be an improvement even if there is more wall-wetting than one might like.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 02-11-2013, 09:55 PM
