964 rod bushings
Ok, this is my first 911 engine rebuild and everything was going fine, utilising plenty of reference books and manuals etc, until I got to replacing the small end rod bushings. I ordered new parts per the parts catalogue only to discover the internal diameter of the bushings are 22.5mm and don't accommodate the 23mm wrist pins. Ordered second set of bushings from a different parts supplier only to discover the same issue. What am I missing here? If anyone can shed some light on this subject I would appreciate it.
HW
Old 02-26-2013, 01:33 AM
bushings
They need to be "pin fit" after installation with the pins you are going to use or a new sample
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 02-26-2013, 05:39 AM
Smart quod bastardus
fredmeister's Avatar
You want them machined after being pressed into the small ends and the big ends checked and machined for roundness.
The shop will machine the bushings at the correct stroke distance and fit them to size to match the 23mm wrist pins.
Usually shops do this as an all in one rod refurbishment and balance them as a set for you too.
Check out an issue of Panorama to find a good shop near you that specializes in Porsche machine work.
Good luck.
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 02-26-2013, 09:30 AM
Aha...the cloud lifts, all is clear! Thanks
Old 02-27-2013, 01:23 AM
