-   -   993 rebuilt top end how long to fix leak? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/734734-993-rebuilt-top-end-how-long-fix-leak.html)
berni29 02-18-2013 04:24 AM
Hi There
I rebuilt my 993 top end and seem to have oil leaks from the cylinder bases. I must have got the Wrightwood green viton gaskets twisted, or else they did not like the smear of hylomar blue I used.
Assuming I have no other avenue but to drop the engine, what is the absolute minimum of disassembly I will need to undertake the gasket change? Can I get the cylinders heads and cam towers off along with the cams and gear all assembled and then back onto the pistons in one go?
Thanks for any advice!
Berni
