-   -   Thermostat test question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/735097-thermostat-test-question.html)
Ed scuba 02-20-2013 09:42 AM
Rebuilding my 1984 911 3.2 engine and as per book tried testing thermostat to see if internal mechanism opens when hot. They say on hot plate I tried fry pan on stove. How hot does it need to get? Thanks
Another question. Can you get parts to rebuild this internal thermostat? I see you can get kit for external thermo. $50 VS $150.
fredmeister 02-20-2013 11:27 AM
It needs to be soaking in a pan of water and open as it comes to a boil. Water boils at 212F and the t-stat should open around 180-190F if I remember.
You can replace the internal element in the t-stat in the wheel well but have to disassemble the thing first. Removing those big slotted caps is tuff and they get damaged easily cause they are aluminum and tend to seize the threads.
good luck.
Ed scuba 02-20-2013 01:45 PM
Thanks that worked and saw the movement.
KTL 02-20-2013 03:18 PM
burgermeister here on the forums informed us that the regulator inside the engine is basically the same as the regulator in the external t-stat
http://forums.pelicanparts.com/911-engine-rebuilding-forum/689055-internal-oil-thermostat-repair.html
tigerbillsbikes 03-06-2013 06:21 PM
T-stat test question
I am rebuilding my 2.4E. As stated in Waynes rebuild book, I put my engine t-stat on a hot plate and sure enough the t-stat opened completely. The hot plate was set on high. I am completely satisfied that mine is working fine.
Bill
