-   -   Need help with timing chains (http://forums.pelicanparts.com/911-engine-rebuilding-forum/735509-need-help-timing-chains.html)
CarreraWSJT 02-22-2013 05:15 PM
I am doing the top end of a 3.2 and am at the stage where I am installing the sprockets to the cams. The timing chain on the right side seems to have come off the sprocket on the intermediate shaft. The crank will only rotate about 30 degrees before lock up. How do I get the chain back on the internal sprocket? The left chain rotates with the crank but the right side is slack and does not move with the crank.
Thanks,
Bill
Ronnie's.930 02-22-2013 07:37 PM
If you do a search for "timing chain" you will find quite a few threads that will help (like these) -
http://forums.pelicanparts.com/911-engine-rebuilding-forum/631425-timing-chain-help.html
http://forums.pelicanparts.com/911-engine-rebuilding-forum/622226-chain-fell-off-intermediate-sprocket.html
CarreraWSJT 02-24-2013 10:22 AM
Got it. Thank you very much.
Bill
