oil in heat exchanger
hello
This is my first post so please bare with me. I have a 73 911T that Im in the process of getting on the road again ,car has been sitting for 10 years in my garage undergoing a body restoration which is now ready for paint. the engine had 80,000 on it when bought (rebuilt) an smoked a little out of exhaust. now Im into the motor and was hoping to replace gaskets ( bought full set) and tidy it up but noticed oil in the heat exchangers. I found #1 and #6 cylinder head exhaust valves coated with crusty burnt oil. would this be a indication of bad valve guides or piston rings and what is the best way to check? was hoping to get by on the cheap and do the top end next year, I however found a guy that I can get some heads from that would get me by if its the valves.
thanks
Tom
Old 03-10-2013, 12:11 PM
Straight shooter
Lapkritis's Avatar
Could be either but also stem seals. Leakdown test would tell a better story. Would not bother with other heads unless he has a full set that has been serviced and cut to equal height and you have determined that to be a better option financially. Throwing in an odd cylinder head on these engines isn't as simple as it sounds as if the height is different from the others then you will have cam issues.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 03-10-2013, 12:49 PM
83 911 Production Cab #10
JJ 911SC's Avatar
My SSI's are leaking air at the seams. Since I was dripping oil from the lower covers, it made is way in;
Who Will Live... Will See
Old 03-10-2013, 01:04 PM
