-   -   Fully threaded head studs - what are they? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/736591-fully-threaded-head-studs-what-they.html)
toddu 02-28-2013 11:24 AM
In the process of tearing my engine down. I have the heads off, but not the cylinders yet. Best I can tell, the whole stud is threaded? I wasn't expecting that. Any idea what iteration of head studs I might have? I'm pretty sure they were replaced at some point in the engine's life.
Todd
fastfredracing 02-28-2013 11:55 AM
I believe that would be 993 Dilivar. Which is a good thing.
yelcab1 02-28-2013 12:01 PM
yup, off the 993 models.
toddu 02-28-2013 12:35 PM
So, definitely reusable? I was hoping to have the case tumbled to clean it up. Maybe just hot tank it then?
Todd
KTL 02-28-2013 01:41 PM
Actually 993 twin turbo. Regular 993 are all 24 steel studs.
Steve Weiner is a big proponent of these 993TT studs for performance usage. They're the latest and greatest iteration of Diilvar studs and that's supposed to be a good thing.
Bill Verburg 02-28-2013 01:59 PM
These are the good ones, used on 993RS and 993tt
http://forums.pelicanparts.com/uploa...1362088663.jpg
toddu 02-28-2013 03:25 PM
Looking through some paperwork that came with the car. Looks like these used to be part number 93010117002. Superseded with part number in the pic above.
Todd
Bill Verburg 02-28-2013 03:47 PM
Todd
Nope, the .02 studs are also fully threaded but were used on base 993
Bill Verburg 02-28-2013 03:59 PM
Todd
Ok I see where that comes from, originally the base 993 used the .02. They eventually issued a TSB to only use the .51 but that was for all air cooled 911 rebuilds
http://i1087.photobucket.com/albums/...Bcasestuds.jpg
toddu 02-28-2013 07:43 PM
Still good, or recommendation would be to replace them?
Todd
WERK I 02-28-2013 08:09 PM
Todd
My $0.02, replace 'em. Use a good aftermarket stud (Raceware, Supertec, etc.). The ".52"'s are outrageously expensive.
I put the .52's in my rebuild (2002) before the prices went through the roof. No problems with them ever.
KTL 03-01-2013 08:41 AM
Actually the Dilivar stud that is 930.101.170.02 was the smooth style only threaded at the ends. The 911 turbo engines have always had all 24 studs in dilivar flavor. That 930 part number is currently superseded by the 993 all-thread ending in .53
The all-thread appears to have arrived with the 965 3.6 turbo engine around 1993-1994. They used 12 of the regular 930 dilivars and 12 of the all thread (ending in .51).
A noteworthy aside here is that the 964 engines (even the 965 3.3 turbo) used 930 dilivar studs for all 24 studs.
Then the 993 comes along and the regular 993 gets steel studs p/n 993.101.171.02 (now superseded to .03 which is also steel). I have these 993 steel studs on my "race" engine, which I bought from Pelican last year.
Then the 993RS and 993TT come along and they get all-thread dilivars for all 24 studs.
Weird how the dilivar usage hops around on these engines, isn't it?
We might be interested to know what the 996TT uses, since that engine is based on an air cooled case. It uses 24 studs that are p/n 996.101.172.70, which coincidentally are the same studs the GT3 uses. They're fairly cheap @ only $17 each. So they must be steel? I suspect the water cooling negated the need to install the dilivar studs.
kenikh 03-01-2013 10:16 AM
Damn - cheapest I can find them is $38/ea. $900 for 24...doh! Pelican Stock
KTL 03-01-2013 10:22 AM
Makes the Supertec studs a bonafide bargain, doesn't it? :D
kenikh 03-01-2013 10:24 AM
I bought the Supetec head studs. They are art.
toddu 03-01-2013 11:55 AM
Definitely confusing. The paperwork I have says 93010117002 - Dilivar Head Studs X 24 ($599). But, they are definitely fully threaded. I don't have a date, but based on other paperwork with the car I would guess early 90's perhaps, but that could precede the 993. A mystery. I'll leave them in and let the engine builder decide what to do with them. I had thought about having the case media tumbled, but I guess I'll just have it hot tanked.
Todd
chris_seven 03-02-2013 06:48 AM
The subject of head studs has been debated in this forum for many years and prices just seem to keep on increasing.
Standard steel studs are around $400 a set with nuts and washers.
Good Quality aftermarket studs seem to average at around $650 a set
The latest 993 Dilavar parts are $1500 without nuts and washers.
All of this for a stud with a torque of 24-25 lbsft.
Grade 8.8 bolts can be safely torqued to 34 lbsft so I wonder why we need to use ultra-high strength super alloys that were developed for the hot sections of Gas Turbines when simple bolts will probably do the job.
4 feet of a Grade 8.8 All thread has a cost of about $4 and would make 6 studs so 24 studs would be less that $20.
Seems quite good value.
Grade 10.9 all thread is about twice the price an even so cost would be less than $50 per engine.
Seems like quite a good saving :)
onboost 03-06-2013 11:38 PM
Hmmm, that is an interesting thought..
Speedy Squirrel 03-07-2013 07:11 AM
The subject of head studs has been debated in this forum for many years and prices just seem to keep on increasing.<br>
<br>
Standard steel studs are around $400 a set with nuts and washers.<br>
<br>
Good Quality aftermarket studs seem to average at around $650 a set<br>
<br>
The latest 993 Dilavar parts are $1500 without nuts and washers.<br>
<br>
All of this for a stud with a torque of 24-25 lbsft.<br>
<br>
Grade 8.8 bolts can be safely torqued to 34 lbsft so I wonder why we need to use ultra-high strength super alloys that were developed for the hot sections of Gas Turbines when simple bolts will probably do the job.<br>
<br>
4 feet of a Grade 8.8 All thread has a cost of about $4 and would make 6 studs so 24 studs would be less that $20.<br>
<br>
Seems quite good value.<br>
<br>
Grade 10.9 all thread is about twice the price an even so cost would be less than $50 per engine.<br>
<br>
Seems like quite a good saving <img src="http://forums.pelicanparts.com/ultimate/smile.gif" border="0" alt="" title="Smilie" class="inlineimg">
They will expand too much, and the torque will be lost. If you torque them higher the barrels will be distorted when the engine is cold. So now you see the problem. Also the material for the 993TT studs is not Dilavar.
chris_seven 03-07-2013 11:38 AM
There is no reason why a Grade 8.8 Steel would expand any more than the standard steel stud. The Coefficient of Expansion of most engineering steels are within 1-2% of each other and this variation is negligible.
Dilavar expands around 50% more than ferritic/martensitic steels and and they don't lose preload - at least until they break.
The description used by our Host for 993 studs is as follows:
993 - fully threaded, DILAVAR, 911/911 Turbo (1965-98)
I was trying to have a discussion on why we all believe the more exotic the material the 'better' the stud when in fact the application is not particularly demanding in terms of metallurgy.
My old 500cc (Single) Velocette Venom Thruxton used to produce around 45 BHP which is equivalent to 270BHP from a 3.0 litre and it had 4 really cheap studs that were nothing special.
Manx Nortoms produced around 55BHP in 1963 (330 BHP equivalent) and again used 4 x simple studs.
Today with all of the modern advances we seem to need $1000 of high end Precipitation Hardening Superalloys to do the same job that was done in the Sixties with materials that were not much better than mild steel.
I guess this is what we call progress. :D
