Two questions:
Are these measurements or calculations? If they were calculations, what type of aluminum was used in your calculations. It's my understanding that Silicon added to aluminum greatly reduces expansion. Mahle is well known for using high Si content aluminum. Those formulas are proprietary and well protected so it's hard to judge exactly what they are using. If I'm reading your number correctly, the difference in squish area would result in about 1.35cc change. It is not uncommon for unmolested chambers to be 2-3cc different. 1.35cc change would result in a .16 change in compression ratio. Almost undetectable on a dyno and undetectable in real life application. |
the relative distances between coarse and fine pitched threads are all relatively large so I am not sure that this is very significnant. The level of stress is still the most likely cause of any difference. |
2618- T61 Aloca developed alloy which has very good strength at high temperatures and is great in Turbo engines. It has a high melting point and a wide freezing range but it has relatively high expansion. It isn't great at scuff resistance and can be prone to ring groove wear. Hence coated skirts and anodised ring grooves. It is easy to forge. Expansion 20.6 ppm per degK Eutectic alloys such as 4032-T6 About 12% Silicon - lowest melting point of any Aluminium Silicon Alloy and a very narrow freezing range makes it ideal for the manufacture of die cast pistons. It can be forged but is more difficult than 2618. It has better scuff resistance and usually exhibits good ring groove behaviour. Very similar to the material used by Mahle for 911S pistons and the like. It can suffer from Silicon migration after extended time periods but is a good stable material that has stood the test of time. Coefficient of Expansion 18 ppm per degK Hypereutectic Alloys Around 16% Silicon - some free Silicon is present as 12.7% is about the limit if solubility. Hypereutectic 390 is a typical alloy. It has good cold strength, possibly a little better than 4032-t6 at moderate temperature. It has excellent scuff resistance and very strong ring grooves. Expansion is about 17ppm per degK. This alloy is relatively modern and wasn't around in the days of Air Cooled 911s. |
Thermal Expansion Metals
No huge difference in expansion rate for these alloys, range is 12.8 to 13.2. The difference may not be significant if one did not take the gap change into consideration but could play part of a cumulative effect solution. Metal Temperature Range (oF) Thermal Expansion (microinch/(in oF)) Aluminum 68 - 212 13.1 Aluminum Alloy - 2011 12.8 Aluminum Alloy - 2017 13.1 Aluminum Alloy - 2024 12.9 Aluminum Alloy - 3003 12.9 Aluminum Alloy - 5052 13.2 Aluminum Alloy - 5086 13.2 Aluminum Alloy - 6061 13.0 Aluminum Alloy - 7075 13.1 Chris - do you know the RS piston material rates? Is it the 4032? Thank you for posting the 2618 rate. This is the material JE uses in their forged pistons. |
Thank you for the piston material but my question was about cylinder material.
We know that Mahle used at least two different aluminum materials. Do you have that data? |
You're welcome. That list is not just piston material.
Mahle is an aluminum blend and we know the ranges of expansion for the materials class which is quite small. I can take these to a local lab for a spectro analysis and have both confirmed but I think it would be a waste of time and money if it's .2 coefficient different. If you're confident they have a magical formula then perhaps you could prove me wrong and test a set on your own. |
I have engine build formulas that has proven track records, with 28 years of constant development and improvement. Most people are looking for just that, a formula that works. My purpose on this forum is to ensure that the least number of DIY builders travel down the rabbit hole to never never land. |
I find the whole subject to be strangly amusing.
People are at odds as to what configuration is best. There is no one correct answer...what works for one builder may not have the results another builder is looking for. Henry has been around for a long time...I trust his judgment...and that is because he has tried and failed at several configurations...to end up with one that works consistantly for him. As for Andrew...I don't know...he may be a great builder...but the history is not there...perhaps in several years he will build enough engines for other people so that his rep will be confirmed. Time will tell...until that time...I believe this discussion is moot. Bob |
I'm not a shop so I only plan on this one engine and one car like many DIY folks here. Relatively speaking this one engine/car is quite an undertaking for me. I guess if you're trying to protect me from myself then I owe you a thanks; your intentions are good. At the same time I should tell you I've been DIY'ing pretty successfully for quite a long time. I've picked up a few tricks and I look 10x's before I leap. If I screw this one up then it's all on me and I'm okay with that. I have a back-up plan and I would suggest anyone trying anything unproven do the same. If the experiment here ends in catastrophe for me and my delicate magnesium case, I hope people have an opportunity to learn as I share my open book of notes, calculations, reasoning and methods. |
The results of precision measurements for the cylinder bores for the QSC 92mm cast iron jugs were all out .0007" to .0008" top to bottom. You may not notice if you slapped them in and ran them at 3.622" as the margin is not that bad at all.
JE pistons part number 261665 PORSCHE 911 2.7L 92mm 9.5:1 are sized 3.6205" with a manufacturer disclosed margin of error of +/- .0005". This means you can order off the shelf from JE pistons and precision hone the QSC off-the-shelf jug to fit. I would hold lower confidence in the QSC aluminum cylinder nickies longevity of service without analysis of the bore and the limited possibility to machine the bore due to the thinness of the coating. If you didn't mind paying out to recoat then it might not matter. All the facts for now. |
I was searching on Google this morning for anti-corrosive cylinder coatings and came across this thread ( http://forums.pelicanparts.com/911-engine-rebuilding-forum/261925-painting-cylinders.html ). Head vs. cylinder, different but just noticing.
2013: Quote:
2006: Quote:
Again, what gives?
2006: Quote:
Surely the paint that was used on the SR71 had a ceramic base and hence significant resistance to heat.
Apart from Black Bodies having good heat rejection due to its emmisivity approaching 1, most Ceramic Paints cause heat to be retained as they have relatively low heat transfer coefficients and behave as insulators. I fail to understand the argument about increased surface area as this would inevitably increase drag and defeat the whole object on a plane that flies at the speed of a Blackbird. :confused: |
Blackbird aside, I'm curious where measurements from the 80's came from that were provided this year (2013) but didn't exist in 2006.
Paint
What I remember in school, the primary process of the SR-71 paint was to help absorb radar waves to help lower its signature, early stealth technology. Then of course the paint had to survive the heat generated by its Mach 3+ envelope. Interesting fact, the airframe would stretch a foot in flight due to thermal expansion. I think those 9000 rpm engines Henry is building have some Blackbird DNA. :D
We can talk about the skunk works and leaking fuel until the airframe was up to temperature in flight... start up with two supercharged v8 engines.
Still curious on the data that was presented by Henry. |
Andrew,your obsession with Henry is starting to look a little creepy!
Present your data and we'll evaluate your conclusions. |
Of course I'll present my information when it is ready. The fact that misinformation was provided to say I don't know what I'm doing rubs me the wrong way. It should rub everyone that has read this thread the wrong way especially if they believed and supported this guy.
Glad someone said it. I applaud someone's desire for facts to benchmark progress. But it is a huge mistake for those involved in research to ignore the learning that comes with the punishing laboratory of practical experience.
Between the economy and the aging out of our cars, those who service our high performance industry are under extreme darwinistic pressure: word of failure gets out quick. Reputations never rebound. Shops are kaput. Look at all the tuning shops that have closed over the last five years alone. I can nr several just my area. Part of science is observation of what works and survives over time and learning from that. I think the experiences of Henry, Steve and other who do a lot of this should be well heeded. Or be prepared to suffer what doesn't work. This ongoing obsession seems up have little to do with progress or sharing information. |
Sounds great. Let's accept lies as facts because of who this guy is around here. Get real.
Put yourself in my shoes for a minute - another person provides false information to further their agenda and position in an effort to discredit yours. Mentioning this and asking for an explanation doesn't make me obsessive. It makes me angry. I don't like being lied to; I'm going to confront it and call the BS out. |
| All times are GMT -8. The time now is 02:58 PM. |
