valve to piston clearance
Thanks for the info Walt. The engine is out of the car in the process of rebuilding.
I bought a 1/4 threaded rod with nuts and washers. I pulled the rocker shaft out towards the oil cooler area. Easy. I believe my clearance problem is a result of my improperly setting the cam timing. I decided to loosen the large cam nuts, remove the tension (at this time lt side only). I will recheck it this weekend. I am hopeful that will solve the #4 valve to piston issue. Thanks, Bill Freeman |
| All times are GMT -8. The time now is 05:27 AM. |
