Max moritz pistons ...but need rings and ideas on build up
looking to build up a SS 3.2 with Max Moritz pistons cis and 964 cams( if they clear)
But I will need rings, where should I be looking for rings? any thoughts and ideas most welcome Thanks steve |
Still looking for rings for the pistons....having no luck at EBS
Have you considered Total-Seal?
You would need the dimensions to order...but it would solve your problems. Bob |
machine the oil ring groove to fit std 4mm goetze rings. i did that on the last set when even peter @ andial didn't have them.
Engine build
http://forums.pelicanparts.com/uploa...1371551074.jpg http://forums.pelicanparts.com/uploa...1371551127.jpg |
| All times are GMT -8. The time now is 12:14 PM. |
