Camshaft Gears - Reuse or Replace?
Currently ordering parts for rebuild. I know Wayne says in his book that timing chains should be replace but what about the camshaft gears? Are these generally replaced? The car has 95K on it.
Here are some photos. It is an early 993 so it has the gear with the pin holes. Some of the holes have a half-moon shaped wear. Is this something happening during manufacture? How to evaluate condition of teeth? ![]() ![]()
I'm about to face the same issue. I'll change chains but keep the gears.
My gear, like yours, looks good.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
I believe the general wisdom with a drivetrain like this is to replace chains, cam sprockets and intermediate sprockets as a unit when possible. I'm no expert, and I can't offer a recommendation, but yours looks like it is showing some wear in terms of tooth length. The sprockets I pulled off of mine looked similar, but there were a few teeth worn more than the others. I replaced all, but I'm sure I could have run what I had for a while.
Here's what a new one looks like.
The side of the sprocket looks worn to me.
It would appear that the chain was running slightly off center. For longevity's sake...I would replace all components at the same time...I always do this on motorcycles...it's not worth the time and effort to take it apart a second time to do it right. Spend your money once...not several times. Bob
Bob Hutson |
Air Medal or two
EZ now.............So much harder latter!!. like said........it all works better as a NEW set
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
Y'all convinced me. I'm replacing all 4 sprockets and chains.
Puny Bird
My gears look the same as the 2nd pic, intermediates don't show any wear.
I'm thinking of at least replacing the cam gears.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
Green...don't forget the chain ramps too.
Bob
Bob Hutson |
My feeling now is in for a penny, in for a pound. Hey, I'm in there already and it's only another $120 or so. I might as well restore the sub-system to new.
Yes, all new. One crumbled upon removal but I might have forced it a bit much.
