-   -   cam timing specs (http://forums.pelicanparts.com/911-engine-rebuilding-forum/742842-cam-timing-specs.html)
wrenchhead944 04-04-2013 03:15 AM
cam timing specs
Hi
I am having trouble finding the cam timing specs for a type 911/01.
Can anyone help ?
Brian
wrenchhead944 04-04-2013 03:16 AM
everything I can find refers to a 901/01
crummasel 04-04-2013 06:27 AM
As both have same camshafts you can use the same spec.
wrenchhead944 04-04-2013 07:42 AM
Thank you very much. That helps a lot .
Brian
