Need advise on loose oil return tubes
Can anybody out there advise me?
I'm assembling a 3.0 liter after a valve job; I'm using new o.e.m. solid tubes w/ new o-rings, & they're loose in the case & cam housing. Initially I thought that as I torqued everything down, the tubes would tighten in their holes. At the moment, the heads are hand tight on the studs, with the cam housing torqued to spec. to the heads.
The return tubes are still disturbingly loose. I'm now reluctant to assume that torquing the heads to the case will change much. I don't want to waste the head gaskets, and can pull the housing & heads back off as an assembly if I need to.
I've triple checked the part #s for application.
What do you guys think? Thanks for any & all help!
Old 04-06-2013, 12:11 PM
Sounds like you may have the wrong O-rings installed on the tubes. The correct rings require a lot of force to compress them.
Old 04-06-2013, 12:17 PM
Thanks for responding earossi; I'm using part # 999-707-112-40 o-rings; is that not right?
Old 04-06-2013, 12:26 PM
Thats the right number, they should be green and need to be greased liberally to fit into place with lots of resistance as you load the cam carrier and heads.
The o rings need to be greased and then inspected to make sure they are not twisted and crushed on install and seat all the way.
I cant inmagine loading them being easy or loose.
Bruce
Old 04-06-2013, 04:18 PM
Straight shooter
Lapkritis's Avatar
They should be a little loose front to back, not side to side. This is so they can move as the stack heats and expands.
Edit: be gentle with them, they're very easy to crush.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 04-06-2013, 04:26 PM
Oil return tube seals.........
bkb500,
I think you have the wrong seals. See part #999-707-113-41-M260.
Tony
Old 04-06-2013, 07:15 PM
Thanks, for all your feedback. Here's what I learned in the interim.
I found that I had a spare billet expandable tube by Rauch&Spiegel, so I compared it to the o.e.m. tube. With the o-rings on the respective tubes, the o.e.m. measures 37m.m. O.D. w/ a 5m.m. C.S.; the R&S o-ring mounted measured 38 m.m. O.D. w/ a 6m.m. C.S.
I test fitted the R&S tube, and found it to be the way I would expect it to be. Also, I installed one of the o-rings from the R&S tube on to the o.e.m. tube, and it fit like a glove.
I can only deduce that the o-rings I purchased from Pelican are mis-packaged.
Thanks again for all your replies.
Old 04-07-2013, 05:55 PM
