-   -   bracket identification (http://forums.pelicanparts.com/911-engine-rebuilding-forum/744031-bracket-identification.html)
jomalkay 04-11-2013 05:53 AM
bought a disassembled 3.2L motor, nearing the end of rebuild and i have unknown bracket. Part was in bags with the cam tower oil lines. I have had no luck finding on parts lists, need some help identifying the small bracket.
jomalkay 04-11-2013 05:59 AM
sorry, forgot picture.
http://forums.pelicanparts.com/uploa...1365685162.jpg
Flat6pac 04-11-2013 06:20 AM
left side chain box top with the 8mm nut supports the spark plug wires.
Bruce
KTL 04-11-2013 08:14 AM
Bruce
Yep. Bruce is the man as usual.
jomalkay 04-11-2013 08:32 AM
Thanks Bruce. won't use this one going twin plug. Can you use the part? can have it for nothing, be good to be put to use, I did re-plate the part, was after my plating learning curve, so the plating turned out really nice.
Flat6pac 04-11-2013 09:13 AM
Thank you, but no thanks as I would have to detail everything to that level....I just like clean.
Bruce
