-   -   901 trans output flange bolt torque? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/745712-901-trans-output-flange-bolt-torque.html)
914magazine 04-21-2013 09:48 AM
What is the torque spec on the 901 transaxle output flange bolts? Coarse spline 100mm, in case that makes a difference.
Also, are the output shaft seals a one shot deal. The trans was rebuilt less than 250 hours ago so is it likely I can reuse the seals or will they get hosed when I remove the output shafts from the trans?
More info: I'm replacing the output shafts to go with a larger CV. Dedicated autocross car, 914 with a hot 2.7 is popping CV cages so I'm moving up to 100mm. A common upgrade, known to solve the problem.
Thank you in advance for your time
Mike
Steve@Rennsport 04-21-2013 10:40 AM
18.8-21.7 lbs-ft.
914magazine 04-21-2013 12:15 PM
Thank you very much, Steve. Greatly appreciated.
Mike
