-   -   Step 1: Clean (http://forums.pelicanparts.com/911-engine-rebuilding-forum/746404-step-1-clean.html)
ned911 04-24-2013 04:04 PM
Step 1: Clean
Before beginning tear down how are you cleaning the motor and tranny? Put on stand and spray with degreaser with a drip pan underneath?
AlfonsoR 04-24-2013 04:13 PM
I haven't begun my first rebuild (really close) but I was thinking of taking it to the local car wash and pressure washing it on the back of my truck. I would remove the intake manifold first and tape up the inlets to the heads.
HawgRyder 04-24-2013 11:11 PM
If you go with a water based system...you have just hours to completely disassemble before the rust starts!
Hot tanking might be a solution.
Bob
toddu 04-25-2013 05:45 AM
I disassembled mine as it was and then hot tanked the parts....
Robey5 04-25-2013 06:54 AM
I am unsure how far you are going to tear down the engine: but if you're doing a soup-to-nuts tear down (splitting the case), I would recommend that you pull it a part and clean them in a hot bath when separated/dissasembled.
If you're just doing a top end - I would cover critical areas and give it a start with carb cleaner and/or brake cleaner and a tooth brush.
I am not much a fan of using water or a pressure washer to clean the engine parts whole or in parts.
Good luck!
