3.0 Rebuild Plan
I've removed and tore down the engine, but decided to leave the assembly in the hands of someone that knows what they are doing :).
Still finalizing some of the details, but it should look something like - 3.0 case Oil mods on crank/bearings 964 Oil pump 3.2 heads, rebuilt/twin plugged PMO 46 Carbs RarlyL8 headers Twin plug dizzy 3.2 Cylinders (not sure if these will stay 95mm or go to 98mm) High compression pistons Twin MSD 67AL boxes New wire harness Lightweight PP/Flywheel Should be pretty impressive over stock. Todd |
....and spendy :D
sounds a lot like my build. SmileWavy |
| All times are GMT -8. The time now is 02:49 PM. |
