Please try your best to limit your statements to anything but what you think I said. |
Wow.
What ever way, they seem to be deducing by experience that when a material is too soft, that it has been caused by overheating. If you really want to know, calling the folks at Millenium is probably your best bet. |
http://www.lnengineering.com/reconditioning.html
LN advertises welding as part of their reconditioning services. |
Nickies are not Mahles and as such utilize different materials. Different materials react differently to differing processes. Different aluminum alloys respond differently to welding processes. There is also the different in process. The Nickies are forged and the Mahles are cast. This difference in structure also creates a challenge. Nothing new here. |
I'm guessing you didn't open the link. The welding is for reconditioning historic cylinders, not his new production LN Nickies. Still knowing everything? Nothing new here.
From the link: Quote:
Sometimes what you know is more important than what you read. In this case what I know is that Millennium does all the cylinder repair work for LN Engineering. At this time, Millennium has two sets of my cylinders. One set of Mahles has a gouged cylinder that can not be welded because Millennium can't weld Mahle cylinders. So, just to be clear: if Millennium does all of LN cylinder plating & repair (quote Steve @ LN)and Millennium can't weld Mahle cylinders (quote from Millennium welder) then it seems logical that LN can't weld Mahle cylinders. So now I guess you'll perpetuate the idea that LN lied? I wish Charles and Millennium hadn't gotten draw into the goofy world of Andrew. |
Take it easy there big guy- it doesn't state that on his page.
