bore for main oil pressure piston so tight
I just found out that the bore for the main oil pressure relief piston was too tight on my engine. The piston literally clicks into the the fully seated position. I have to push it out using a wooden stick from the hole for the oil pressure light.
the symptom was very high oil presssure.
I was thinking of using fine rubbing compound to open up the bore
Old 05-12-2013, 08:07 PM
btw, the engine case is a 1976 turbo case
Old 05-12-2013, 08:09 PM
