-   -   How do I get the cam tower seperated from the head? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/750019-how-do-i-get-cam-tower-seperated-head.html)
Speed Buggy 05-14-2013 08:30 PM
I need to do a deck height check but the valve train guy put the heads and the cam tower together with locktight. How do I seperated the two to put the head on one and four?
Lapkritis 05-14-2013 08:42 PM
Check all the nuts and I pry gently *GENTLY* above the port where the meat is thickest to separate. Constant pressure and wiggle, they pop apart.
Should be able to do the deck height with the cam tower attached though, yes? Shouldn't be a problem to only have one or two of the cylinders in place even if you install the piston/cylinders without clipping the piston in at both ends.
Gordo2 05-14-2013 08:52 PM
Separating Heads From Camshaft Towers
Don't know if this applies to what you are doing (heads/towers already removed/on bench?). Here's how I separated mine (they had some sort of bonding agent making it difficult).
I placed a small object (wood handled wire brushes) under the heads that I was not removing:
http://forums.pelicanparts.com/uploa...1368589559.jpg
Then I separated by hitting the studs with a brass drift:
http://forums.pelicanparts.com/uploa...1368589809.jpg
If nothing else - possibly provides some ideas.
Gordo
Speed Buggy 05-15-2013 06:15 AM
I figured I would have to do one of those two things. Just wanted to make sure there wasn't a better way from the guru's here. Kinda scarey prying on the cooling fins. :eek: Thanks again. Cheers, Mike.
Lapkritis 05-15-2013 06:52 AM
Yep, would not pry on the fins at all.
Mark Henry 05-15-2013 07:02 AM
Yep, don't pry on fins and make sure all the nuts are off.
There are areas that have more meat, as long as it's not a sealing surface. Go around and around the tower prying gently, just a hair each time and it will come off.
Speed Buggy 05-15-2013 03:30 PM
Might try w/o separating
Andrew, I think I may try putting the whole thing on w/ a cylinder on each end and only tighten the head I want to measure. If I can't do it that way, I'll separate. Thank you all.
304065 05-15-2013 07:11 PM
I wouldn't recommend that as a reliable way to measure either piston to cylinder clearance or deck height. Best way is to melt the loctite, separate everything, clean it and reassemble the way the engine is intended to fit together.
Lapkritis 05-15-2013 09:50 PM
Unless I'm mistaken, the cam tower is bolted atop the heads on these engines... and it's intended that way. What would cause you to believe the presence of the tower on a fastened head would change the piston to head clearance?
