fred cook's Avatar
Cam gear alignment question.........
I am working on the cam gear alignment on my engine build. In following the instructions in Wayne's book, everything seems to work as it should. However, on the left side, he says to "measure from your straightedge to the left sprocket flange". Then he says "add 54.8mm to the value. This value should be equal to your first measurement". However, since the left side of the engine is "set back", shouldn't the instruction read to subtract the 54.8mm value? Doing it as a subtraction, the numbers come out very close to matching on both sides. The right side comes to 51.56mm and the left side 51.20mm. Everything is so close, I believe that I can move one shim from the left side to the right and everything will be happy. Your thoughts?
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 06-08-2013, 03:46 PM
fred cook's Avatar
Measuring tools
I'm using the Stomski cam alignment tool with the ground Starret straight edge and a good quality digital caliper to make the measurements. Pretty confident in the numbers.
FEC3
Old 06-08-2013, 03:48 PM
fred cook's Avatar
Never mind..........
Just went into Wayne's correction list and found the answer. The number should be subtracted! And, the shims are .50mm, not .25mm.
FEC3
Old 06-08-2013, 03:51 PM
1988 Carrera
shadowjack1's Avatar
Fred:
I went thru the same adventure as you. Thought I was loosing my mind for a time.
Old 06-09-2013, 07:26 AM
fred cook's Avatar
Adventures in mathmatics.......
Originally Posted by shadowjack1 View Post
Fred:
Maybe it is good to have events like this from time to time just to help exercise the ole' brain muscles!
FEC3
Old 06-09-2013, 08:22 AM
