-   -   need help with engine misfire-MSD experts (http://forums.pelicanparts.com/911-engine-rebuilding-forum/750805-need-help-engine-misfire-msd-experts.html)
Daniel930 07-14-2013 08:17 PM
Cold Miss
Fred,
Glad to hear you are making positive progress, not sure how old your injectors are but sounds like a similar problem I had. I did remove the old one’s at one time. Tried my best to clean them, reinstalled, same problem. Finally broke down and bought a new set, major difference.
fredmeister 07-15-2013 03:34 PM
Originally Posted by Daniel930 (Post 7548918)
Fred,
Hi Daniel,
The injectors were sent out to be cleaned and flowtested by Turbokraft 2 years ago. They were all noted good and sent back to me. I did make sure to install the best flowing injectors in the #2 and #5 cylinder location since those cylinders recieve the most air flow thru the pancake manifold, in an attempt to balance AF ratio between all the cylinders.
Later,
Fred
fredmeister 07-15-2013 03:49 PM
Here is a screen dump of my stock ignition curve that I have programmed into the MSD box.
Welcome any feedback from anyone on what they think or improvements I could make.
http://forums.pelicanparts.com/uploa...1373928575.jpg
